Sometimes a clunk when backing up
Old Nov 4, 2012 | 09:50 AM
bostongrun's Avatar
Default Sometimes a clunk when backing up
I have a 99 Accord Ex, Auto with 122k. I just swapped engines. Now it sometimes make a clunk or thump when going into reverse. It goes into reverse fine, no clunk but sometimes after going backwards about five feet it clunks. It doesn't do it in any other gear. I replaced the forward transmission mount and big round engine mount on the right side.
The tranny has no other issues like slippage or rough engagement.
Any ideas?
Old Nov 4, 2012 | 10:22 AM
Glad to see you are back on the road.....sounds like you didn't damage the trans.
I would inspect the rear mount to be sure it is ok.
Old Nov 4, 2012 | 08:08 PM
bostongrun's Avatar
No I didn't damage the transmission thank the Lord.
One good thing about a bad mistake is that you never repeat it.
I actually paid a guy 450 to reinstall the transmission. I did notice the rear trans mount doesn't look like it is aligned right.
Old Nov 5, 2012 | 06:09 PM
Good to know the trans is ok.....bet you won't go back to that parts store
Check the mount, the alignment could be a few things.....busted mount, bracket not right, other mounts out of alignment as well?
Old Nov 6, 2012 | 06:16 AM
Is it a 4-cyl or a V-6?
The shop manual talks about aligning & tightening the engine mounts in a certain order. Look that up, so all the mounts are sharing the load in the proper proportions.
WindPhoenix
Aug 10, 2012 10:15 PM
danh
Oct 17, 2011 07:11 AM
chillnndc
Sep 29, 2010 07:56 PM
cuatro201821
Apr 1, 2008 09:06 AM
razcob
Nov 28, 2007 04:51 PM
