Sometimes is hard to shift from park
Old Jan 3, 2008 | 09:02 AM
egonzal24
Default Sometimes is hard to shift from park
This is an intermittentproblem.Replaced the brake light switch; problem still there.
I had followed the DIY "CANNOT GET OUT OF PARK....DIAGNOSE", and everything looks OK.
Do I have to replace the shift cable? is this an easy task?
Any instructions you can share.
As always, ty for your replies.
Old Jan 3, 2008 | 09:29 AM
Default RE: Sometimes is hard to shift from park
Take off all the trim around the shift lever. Then you can see what's going on.
You'll have to decide among acouple possibilities. Without feeling the action of the shifter firsthand, it's hard to tell. The differences are subtle.
Desert's DIY about stuck in park is focused on the brake/shift interlock system. That's most common, but you say that stuff is OK (right)?
It could be a dirty/rusty/sticky shift cable. In that case you could disconnect the cable from the lever (maybe #54 & 37 in the picture?) & make sure the lever itself works OK.
There's a spring-loaded plunger that makes the clicks you feel when shifting. It alsolatches into Psoyou have topress the button #27at the shifter. That could be messed up. In that case the lever would continue to be stuck when the cable is disconnected.
I guess the worst would be internal trouble in the tranny. In that case the cable would move a tiny bit back & forth but the actual lever (at the tranny) wouldn't move easily. You'll have to crawl under & disconnect the cable at the tranny to figure that one out for sure.
Old Jan 3, 2008 | 06:46 PM
HondatechAV6's Avatar
what is the engine rpm when it won't shift out of park? if it's 750 rpm, then you need to inspect the throttle position sensor voltage. if it's not .49v-.51v it will not allow the transmission to be shifted out of park.
another note - when you press the brake pedal do you have brake lights?(i assume so since you replaced the brake switch) do you also hear a soft thump/tick in the center console when you hit the brakes and the car is in park? if not, the shift lock solenoid isn't working. it can either be the solenoid, wiring, or stuck. typical causes of it sticking are from people spill soda and coffee over the years. first check the tp sensor voltage.
letsclique
Jun 18, 2016 04:29 PM
campervan12000
Jun 15, 2011 07:23 AM
pirulino23
Apr 1, 2011 03:00 PM
cuatro201821
Apr 1, 2008 09:06 AM
mori0203
Aug 16, 2006 05:54 PM
