SOUNDS ANNOYING! 2001 Honda Accord
Old Sep 6, 2014 | 01:35 PM
lyndaglenn7@yahoo.com's Avatar
Default SOUNDS ANNOYING! 2001 Honda Accord
PLEASE HELP US DETERMINE THE PROBLEMS.
We have replace a few things and nothing helps.
THANKS!!!
Old Sep 7, 2014 | 07:20 AM
What has been replaced? That will help us rule out some of the suggestions.
Some of these had and issue where the sub frame will rust out - on the pass side about where the ac drain tube is.
Old Sep 9, 2014 | 07:09 PM
My husband has to check his records; he's not sure what 2-3 things he replaced (it was a year ago).
One of the many sounds (all in the front end) is above the front tire.
Old Sep 12, 2014 | 08:00 AM
Then that would make me believe that "something" is going on with the upper control arms - either the bushings or the ball joint.
If it is the control arm, they can be replaced pretty easy. You can get them online for ~$60 each and doing it yourself is not that hard.
argarcia86
Feb 13, 2012 07:21 AM
dbajnath1
Aug 16, 2011 09:39 PM
musicmaniac
May 26, 2011 01:32 AM
strokera4
Jan 31, 2011 12:05 PM
hitek0301
Apr 21, 2009 09:20 AM
