Speed Control
Old Jan 9, 2012 | 06:41 PM
Rogcalcan's Avatar
Angry Speed Control
95 Accord EX 5 speed, 4 cylinder. The cruise does not engage most of the time, the problem has been getting worse the last 2 years, now it seldom works. I've replace the complete unit under the hood with a used one with no change what so ever. Any suggestions?????
Old Jan 9, 2012 | 07:14 PM
If the cruise light doesn't come on when set button is pressed, most likely reason is failed steering wheel switch or spiral wiring coil has a cracked filament. Some diagnostics on steering column wiring should confirm source of fault.
Old Jan 10, 2012 | 03:21 PM
Rogcalcan's Avatar
The cruise light does come on for a second but the cruise does not engage. The odd time the cruise does come on the light does stay on---- no light, no cruise.
Old Jan 11, 2012 | 11:55 PM
Talking Hi |New Member, Not A New Member Post, so..>>..>>
I shall move it to a better forum that it should be in..
socaldave34
Oct 18, 2012 06:09 PM
irhunter
Mar 23, 2011 04:49 PM
Spadinator
Oct 23, 2010 12:50 PM
Nughuffer
DIY Answers.
Dec 10, 2009 09:51 PM
greenbean
Sep 21, 2007 03:14 PM
