Speed sensor issue???
Old Jul 23, 2009 | 12:58 AM
poorboy_616's Avatar
Default Speed sensor issue???
I got weird one for you all....
Earlier today while driving around in the wife's '91 LX (auto trans) the Speedo didn't start moving until it shifted into 2nd gear.
Gear engagement from park to drive was firm as it should be, as was the shift into second....
My question is, why would the speedo read zero (with the car moving) until it shifted into second (around 15 or so MPH)?
It's at random, but may get worse if ignored...
Old Jul 23, 2009 | 04:17 AM
littledrakon's Avatar
its most likely your speed sensor is going bad.
Old Jul 23, 2009 | 03:04 PM
That's what I was thinking...
What symptoms will we have once it fails outright? Other than no working speedo.....
Our 94 T&C (when he had her) would go into "limp-in" with a failure of that sort. Does Honda do the same thing?
Also where is the speed sensor located on this vehicle. I knew where it was on the T&C and on my Jeep, but the Honda is a mystery still.....
Old Jul 23, 2009 | 04:05 PM
If the speed sensor was bad, it should throw a check-engine light. As long as the CEL is not showing (except bulb-check when you first start the car?) then the VSS should be OK. That leaves probably a bad cluster or (less likely) a problem in the wiring harness.
The VSS is on top of the tranny, back against the firewall. Pretty much right above the axle centerline, about a foot below the throttle body.
Old Jul 23, 2009 | 07:14 PM
Gzus help me if the cluster is bad.....
I can deal with the speed sensor, but a bad cluster I won't mess with.....
If it is the cluster, can the speedo itself be changed with swapping in a whole other cluster? I know it's got the two screws for the speedo on the face.....(yes I know the cluster has to come out anyway......
Old Jul 23, 2009 | 07:31 PM
If your cruise control works when the speedometer isn't working, then the VSS is working properly.
Removing the cluster isn't too bad of a job. Download a 91 shop manual from the online manuals thread in the DIY section. It will help you with the job.
You can take apart the cluster on 94/97 accords and replace the speedometer. I would assume that the same can be done on the 91 accord.
Old Jul 23, 2009 | 11:38 PM
Funny that you mention cruise.....
When set it slowly drops in speed, all they down to the point of release....
Hmm.....I have some work to do while the wife is in Vancouver.....
Old Jul 24, 2009 | 02:07 AM
Just to be thorough, see if the cruise control works properly when the speedometer is working.
Old Jul 25, 2009 | 07:56 PM
The only time the speedo seems off is when you first start out, and occasionally it seems to read a little fast when you have been driving for a while....
I will have the car all next week as the wife is roadtripping with my sister and the kids, so I should be able to more diagnostics....
pondrun
Nov 8, 2021 09:40 AM
Afnan
Nov 19, 2013 05:52 PM
socaldave34
Oct 18, 2012 06:09 PM
irhunter
Mar 23, 2011 04:49 PM
Spadinator
Oct 23, 2010 12:50 PM
