speedo problem
Old Jan 11, 2009 | 02:43 PM
flexaccordwagon92
Default speedo problem
i got a 92 accord wagon lx and i have change the vss with a new one, the instrument cluster and still the speedo isn't working. the only code i'm getting is 4 on the d4 light which is the seed sensor which i change already. also the cruise control is not working neither. the d4 light start blinking after a 1/4 of a mile everytime i drive and is not shifting 4th gear. if anyone can't tell me what else to do i will be thankful.
Old Jan 11, 2009 | 04:18 PM
Default RE: speedo problem
Code 4 is an electrical fault in the speed sensor (VSS) circuit. It could be the VSS was not the problem and a wiring or connector fault was the reason for the code. Inspect wiring for damage and make sure all connectors are fully engaged. If all looks OK, you'll need to verify wiring continuity between VSS connector and ECU. Release connector at VSS and ECU. Ground one end say VSS end, and check for ground at other ECU end. If you're missing ground at ECU end, you've found defective wire, but will need to find the fault location somewhere in the wire.
It isunlikely but possible someone sold you a defective VSS.
Suggest downloading a 90-93 manual from one of Online Manuals DIY faq links.
Old Jan 11, 2009 | 04:31 PM
flexaccordwagon92
the speed sensor is oem genuine honda. got it for a honda dealer. the orange wire have continuity to the ecu but the tcu and speedoare not getting any signal for the vss. I test the speed sensor in my brother's wagon which is the same year and model and the speedo works fine so I open the tcu on my wagon and some capacitors and resistors are burned. Do you think thats the problem?
Old Jan 11, 2009 | 04:35 PM
flexaccordwagon92
alsoI thought that if the speed sensor is bad or defective the cel will give code 17. but i'm not getting that code. was getting it before i change the speed sensor
Old Jan 11, 2009 | 04:49 PM
Burned components on a circuit board are not good. However, you might try a reset of ECU/TCU before swapping for a replacement board. I agree code 17 should also be set on the ECU. If no code, then ECU may be toe's up.
Check car-part.com for a replacement ECU near your zip code.
Old Jan 11, 2009 | 07:06 PM
flexaccordwagon92
I also use my brothers ecu and is the same no code on cel but code 4 still on tcu i will check the wiring next weekend and see if that is the problem. also I'm going to replace the tcu. i'll post and update after i check everything.
thanks Texas
96FiveSpeed
May 27, 2012 05:07 PM
gahonda
Feb 17, 2010 11:30 AM
texasktm
Jan 5, 2008 01:21 AM
Edinburger
Mar 9, 2006 04:59 PM
gunslingre
Mar 3, 2005 02:37 PM
