speedo swap
Old Apr 13, 2011 | 08:20 PM
wunderbra's Avatar
Default speedo swap
Car I bought has the wrong gage cluster. No ABS light. I got the correct cluster, but would like to keep my speedo with the odometer/mileage.
Can the speedometers be swapped between the two without much hassle? I don't want to break any plastic parts.
If so, what is involved.
Old Apr 13, 2011 | 08:31 PM
Its pretty easy to swap, You just remove the plastic casing, then remove the 4 screws that hold the speedometer in place and screw the new one in.
It may seem daunting but its actually pretty simple.
Old Apr 13, 2011 | 10:26 PM
wunderbra's Avatar
I can probably figure it out, but is it necessary to remove the front clear lens?
Old Apr 14, 2011 | 06:21 AM
Yes otherwise you will get the speedo loose but not be able to get it off. It doesnt require baking or anything, its just some clips.
Old Apr 15, 2011 | 07:15 AM
wunderbra's Avatar
Okay, does the speedo needle just pull of and press back on?
Old Apr 15, 2011 | 04:23 PM
No, its near impossible to remove the needle without breaking something. You need to swap the entire speedometer or cluster.
Old Apr 16, 2011 | 07:07 AM
wunderbra's Avatar
It turned out much easier than I expected.
After unsnapping the cover for the front lens, there are just 4 silver colored screws on the back of the circuit board ( all the rest are brass) that holds the speedo in the cluster.
Once those screws are removed, the speedo just falls out the front.
PJ_STYLES_95AccordEx
Aug 21, 2006 11:45 PM
che
Aug 6, 2006 01:55 AM
kallen425
May 5, 2006 03:04 PM
Edinburger
Mar 9, 2006 04:59 PM
gunslingre
Mar 3, 2005 02:37 PM
