Speedo Tach and intermittent Starting Issue
Old Apr 27, 2013 | 07:09 PM
RI Accord's Avatar
Default Speedo Tach and intermittent Starting Issue
Hi, I have been doing searches for a couple of days and haven't found any clear path to solving an ongoing problem. While driving, the speedo and tach will drop to zero, the radio dies and the car loses power for about 1 or 2 seconds. The car can start fine sometimes or crank really slowly but start. I had this problem before and replaced the ignition switch and starter. Problem went away for a while. Today I pulled out the year old ignition switch and tapped it while checking continuity. There didn't appear to be any intermittent contact while the switch was tapped on a hard surface. I haven't changed the main fuse yet but the intermittent nature of the problem doesn't seem like that's the issue. I also haven't had temp control button function for a long time. The car is a 5-spd 1999 Accord LX, 4 cyl. Any ideas?
Old Apr 28, 2013 | 07:14 AM
RI Accord's Avatar
I've noticed something else; if I give the car gas and let off suddenly, the gauges and the radio lose power and then it comes back immediately. If I do this while sitting still, nothing happens. Also, today the temp controls are back. They haven't worked for months! Could the movement of the engine be causing something to short or break contact? When I turn on the headlights the maintenance light comes on today. This is crazy!
Old Apr 28, 2013 | 07:41 AM
Check and clean the battery connections. Also check the main ground on the end of the tb to be sure it is clean and tight, #16 in this pic.
Attached Thumbnails Speedo Tach and intermittent Starting Issue-6th-gen-g101-loc-4cyl.jpg
Old Apr 28, 2013 | 10:24 AM
RI Accord's Avatar
Already cleaned the battery posts. I'll check the ground you mentioned. I was pulling on all the harnesses and everything is good for the moment. The temp controls are going on and off now but weren't working at all recently. Seeming like a short or bad ground somewhere. I had a multimeter on the battery as I pulled on cables. I pulled on cable going to fuse box on drivers side and voltage dropped and then everything started working. Now I can't duplicate that voltage drop. I hate intermittent electrical problems! I am getting no codes at all.
Borico4life
May 30, 2011 06:50 AM
Kimota
Feb 16, 2011 10:30 AM
MoDawG
Dec 10, 2009 07:00 AM
fraughton
Feb 14, 2009 11:15 PM
benjiaccord
Sep 8, 2008 05:05 PM
