Speedometer Doesn't Work
Old Mar 27, 2009 | 04:18 PM
swift8585
Default Speedometer Doesn't Work
Hey i am new to this Forum...I just recently brought a 1990 Honda Accord LX auto...It has a few minor problems. The main one is that the speedometer does not work. The rpm's do so i have a general idea on my speed from driving manual cars before but i still would like to get this fixed. My question is..is this car known for the speedometer dying? I have no cel light but the battery was dead when i got it and i only have been driving it for 2 days now so one might still pop. I just want to know if i would be better off just changing the the whole cluster from one at a junk yard or if there is some known wire or fuse that causes this. Also my fuse box inside the car doesn't have a cover. Does anyone have the diagram of what fuse is for what. If so i would really appreciate it if you could post it up for me. And i did do some searching on the forum but i didn't really find anything that would answer my question.
Old Mar 27, 2009 | 05:14 PM
swift8585
Ok in update i found that it is usually the speed sensor that causes speedometer to stop working. So could someone tell me where the speed sensor is? I will also try the cruise control when i leave work today to see if it works. And also my odometer still works with the rpm's
Old Mar 28, 2009 | 08:09 AM
swift8585
"If your cruise control still works when the speedometer is not working, then the speedometer is the problem. If the vehicle speed sensor stops working, the check engine light should come on and the cruise will not work."
OK is that quote true? Because i tried my cruise control and it does work so then it wouldn't be the sensor? Can someone let me know if this is true?
Old Mar 30, 2009 | 06:55 AM
Well, that should be almost true. The VSS creates the signal for both the speedometer & for the cruise control.
But maybe the cluster is OK but the signal doesn't get there. Check for loose connections behind the cluster?
jrock24
Feb 19, 2014 12:26 PM
Ralph
Apr 12, 2012 06:03 PM
jethro
Nov 5, 2009 11:26 AM
cuatro201821
Apr 1, 2008 09:06 AM
seamoore
Aug 26, 2005 02:10 PM
