3 issues bushings, belts, crank sensor
Old Mar 29, 2009 | 03:31 PM
banditrider's Avatar
Cool 3 issues bushings, belts, crank sensor
Hey everyone--Im planning on replacing all front end bushings as a set--I would prefer a set of rubber ones over the plastic sets. Anyone know where to get rubber ones as a set or do I have to buy individual ones?
Planning on doing a complete timing, balance shaft belts and seal job with a water pump as well--I was going to with gates replacements--they are cheaper than honda parts, not sure if they are any good.
I read somewhere that the crank sensor on my F22B2 is located under the timing belt cover, is this worth replacing or should I wait? Car currently has 150,000 miles on it. This will be the secnond timing belt job, last one done around 90,000 miles.
Thks for any help or advice!
Old Mar 30, 2009 | 07:10 AM
Yeah, the crank & TDC sensors are down at the crankshaft. Unless they're giving you problems, I wouldn't replace them just for $180 worth of fun.
pondrun
Nov 8, 2021 09:40 AM
x13darkmatter
Aug 9, 2012 10:04 AM
mugenpaolo
Apr 13, 2009 09:34 PM
academic
Jan 11, 2008 08:24 PM
thunder_x
May 26, 2006 08:18 PM
