spongy brakes, where to start?
Old Aug 28, 2010 | 12:36 PM
falcondfb's Avatar
Default spongy brakes, where to start?
I drove my kids 95 EX the other day and I found her brake pedal very spongy. It still has decent braking power but the travel is a lot compared to what I remember.
I find no leaks in the brake hydraulics, the pads all have plenty of meat, fluid level is same as always, nothing has been touched since I replaced the pads in the spring.
What should I check first??
Old Aug 28, 2010 | 12:43 PM
kris_loehr's Avatar
If you have rear drum brakes adjusting them would be a good place to start, after that bleeding the system.
Old Aug 28, 2010 | 01:20 PM
Bleed the sytem...yes...you might have air in the lines.
Old Aug 28, 2010 | 07:01 PM
falcondfb's Avatar
disc all around. How would air get into lines if there are no leaks to be seen? I will try bleeding tomorrow anyway.
Old Aug 28, 2010 | 09:00 PM
kris_loehr's Avatar
Air could come from a failing master cylinder, a leak, or the system was opened for a repair and not bled correctly. I see bleeding as a diagnostic tool and you will have to address where the air came from.
Old Aug 28, 2010 | 09:22 PM
EXV6NIGHTHAWK's Avatar
Brake fluid absorbs moisture over time. When there is moisture in the brake fluid, it lowers the boiling point. When water heats up, then evaporates and creates air, and there you have it. Honda recommends flushing the brake fluid every three years. Has the fluid ever been flushed? If you have old brake fluid, and an old master cylinder, I would suggest vacuum bleeding.
Old Aug 28, 2010 | 10:11 PM
falcondfb's Avatar
not only advice but explanations as well
I will flush and bleed as my first step Thank you
Old Aug 29, 2010 | 12:44 AM
There you go new member..as we always say..lot's of information here in this forum..
Thanks Men..
HondaWoman
Jul 25, 2012 08:02 PM
wapatano
Aug 11, 2011 07:51 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
