SRS light
Old Nov 12, 2007 | 12:49 PM
caverspencer's Avatar
Default SRS light
My SRS light is on in my '97 Accord EX 4cyl Vtec
Any guesses as to what might cause it?
Do SRS lights have a code like the check enginge light does? If so how do I read it and find out what it means?
Old Nov 12, 2007 | 01:00 PM
sir_nasty's Avatar
Default RE: SRS light
yes it has a code, I believe it will show the code by jumpering the blue connector just like you were reading the check engine code. Unless you have an OBD2 ECU (some 97's did I believe) then you can just run down to autozone and have them pull the code.
Old Nov 12, 2007 | 03:43 PM
I ran to Checker during lunch. They have the ODB2 reader but they say it doesn't read the SRS codes and I need to go to the dealer for the SRS light. [sm=smiley6.gif]
Can I do the trick of jumping the blue clip under the glove box and counting the flashes when turn on the ignition? If so where can I find a list of what the codes mean?
Old Nov 12, 2007 | 03:48 PM
sir_nasty's Avatar
if you have an OBD2 ECU then I don't think the jumper trick works
Old Nov 12, 2007 | 04:00 PM
I think my car actaully has both. I know that you cant actaully jumper the OBD2 connector and it is behind the ashtray. It is the one I read all to often for engine codes.
In addition to the OBD2 connector behind the ashtray there is a couple of conectors unders the glove box. one is a blue conecter and is eaither 2,3 or 4 pin. The other is orange and is about 8 pin or so. I am failry certain I have jumpered those and cycled the ignition and counted the blinks on the dash in the past for something.
Is this making any sense or am I just up in the night?
Old Nov 12, 2007 | 04:11 PM
sir_nasty's Avatar
I might be nuts but I've always assumed that obd2's didn't have the jumper plug, There should only be two wires going to it....
Old Nov 12, 2007 | 04:43 PM
Thanks for all your input so far.
I ran out and took some pictures. Please excuse the messy car.
So if I jump the Blue connector shown will it by chance show the codes? If so where do I find a list of what they mean?
Size:  40.6 KBName:  PICT5022.jpg
Old Nov 12, 2007 | 04:49 PM
sir_nasty's Avatar
I'm just guessing but I looked at a few other threads, it appears that the blue plug does work for diagnostics as well.
Old Nov 12, 2007 | 05:07 PM
nafango2's Avatar
btw you must be going crazy nasty. ALL U.S. cars 96+ have OBDII, its a law.
and yes, the blue plug does work for diagnostics, just jump it with a paperclip, turn the key to ON, and count the D4 flashes.
Old Nov 12, 2007 | 05:10 PM
sir_nasty's Avatar
it's been a long day.... Just found out that Ultimate Warranty Co. is possibly going out of business... The place I work for used to sell their policies so I'm getting yelled at left and right even though I never sold them myself.
