Srs light
Old Jul 20, 2017 | 06:54 PM
angrysmileyface's Avatar
Default Srs light
So I have an airbag light on in my 1995 wagon. Code says 5-1 (internal fault) checking places like Honda parts now or any of the other dealer based sites say the computer in this case is specific to my model year. Can I substitute another to year without issue. Also the airbag light seems to alternately flicker with the turnsignal indicator when it flashes. My abs light did as well when it had a problem. Would any of this be related? I bad ground causing air bag light or faulty voltage stabilizer?
Old Jul 21, 2017 | 08:41 PM
When strange electrical issues happen like you describe, you probably have a ground issue with the instrument cluster. It could be a problem with the ground connection or possibly corrosion on the circuit board.
The SRS code is probably correct with a 5-1. Your OEM part number lists all the 1994 accords as exact matches. Probably best to find a used 94 SRS control unit. You could likely use one from another year, but I have no idea what is different on the module.
Old Jul 21, 2017 | 08:45 PM
Is the 94 compatible with my 1995 ex wagon? I was under the impression it wasn't. But I can always try the 1994 and see where that gets me. In the mean time I will track down the dash grounds
OneEyed
Jun 25, 2015 05:32 AM
brayner
Feb 12, 2013 06:59 PM
01AccordLX
Apr 4, 2012 01:39 PM
01hondaccordlx
May 18, 2005 11:51 PM
bj70alex
Nov 22, 2004 01:56 PM
