SRS light Not coming on
Old Apr 9, 2013 | 09:29 PM
camman's Avatar
Red face SRS light Not coming on
I have a 97 accord SE and when i turn the ignition on the SRS light don't come on, i want it to work so it can tell me if Theres a fault in the system or something. i have not messed around with the MES yet cause i dont want to mess up and deploy the airbags. is it a bulb? How do i fix it? how much will it cost?
Old Apr 9, 2013 | 09:44 PM
You check SRS codes by shorting the OBD1 connector under the dash. You reset codes by shorting the MES connector.
You can try checking codes.
Your problem can be from a bad bulb, the wiring, a blown fuse, or the SRS unit. You need to troubleshoot before repairing.
In the common diy thread on top of the gen tech help forum, there is a link to online shop manuals. Get the 94 accord shop manual from the hondatech link.
On page 23-332, it has the diagnostics for a SRS light not turning on.
MSC71
Nov 23, 2019 05:28 PM
Winston Hart
Sep 7, 2013 12:32 PM
camman
Aug 18, 2013 07:40 AM
JJC
Mar 13, 2013 06:17 PM
N1Accord
Mar 24, 2011 11:27 AM
