SRS Module connector
I would like to say that no one has responded as there is no information on the year, make or model of the car and it is a safety issue as you are currently aware of. Information is need in order for some one to help you. Thanks and welcome to the HAF site!
My Bad.... 1998 Accord EX 4 cyl. As to a safety issue, being aware of discharging the electrical system with the battery disconnected and a load turned on for 3 minutes (Per repair manual) is sufficient not to accidentally deploy any air bag. I was successful in disconnecting the steering wheel airbag at the connector under the steering column. I am at the point per instruction to disconnect the module in order to remove the dash assembly from the car to gain access to the HVAC unit. I'm also replacing the Evap core because I'll be right there, and the car is 17 years old... and the customer wants to thwart that as a probable major expense in the near future.
Chris Jameson
Feb 19, 2013 06:39 AM
