SRS warning light
Old May 26, 2009 | 10:35 AM
jarede7's Avatar
Default SRS warning light
The last few days my SRS warning light has been coming on in my car. It won't come on during every trip but during about 1/3. From my understanding the light counld be triggered by one of countless sensors in the system or the belt tensioners. Does anyone no how I could narrow down the list of possible culprits? I took a quick look in my factory service manual and the first step was to read the code with the scanner which I do not have. Will the trick of shorting the system and reading the blinks give me enough information? I wonder if I should just take it to the dealer and let them diagnose then replce the part myself, essentialy using them for their scanner.
Old May 26, 2009 | 10:44 AM
jarede7's Avatar
After some searching it seems that I can take the car to autozone and they can pull the code. Is this true? Will is give me the exact/sensor component which I can then fix?
Old May 26, 2009 | 11:12 AM
hondadude's Avatar
if you get the code it doesn't always mean there will be a part to replace.
Getting the code will help you to do a correct and accurate diagnose.
Every code has a diagnostic procedure on the honda interactive website.
Old May 26, 2009 | 11:45 AM
jarede7's Avatar
Cool, thanks.
brayner
Feb 12, 2013 06:59 PM
eddyaccord
Feb 6, 2013 10:10 AM
dmjole
Aug 21, 2012 06:02 PM
01AccordLX
Apr 4, 2012 01:39 PM
mluthier
Jul 28, 2008 10:06 PM
