Starter issue?
This is the 4th starter, and still under 100k...The starter spins but didnt engage to the crank/fly wheel in order to turn the engine over. The new starter does the same thing. After the 2-3 attempt the car will start and run perfect...Im not sure if the fly wheel could be missing teeth.
Some parts stores can test the battery, alternator, and starter. They hook up their tester to the car and takes little time.
I remember I had this done once and they said my starter was not getting enough power. It wasn't too long before I was replacing the contacts for the solenoid.
All the relay does is supply battery to the starter. If it cranks then it is not likely the relay. I had a starter/flooding issue in my 89 Accord that resolved itself when I replaced the battery. I thought the battery was good. Check the voltage, it is an easy check with a $15 meter from Harbor Freight.
tony_toca
Feb 4, 2011 10:10 AM
