Starter issue?
Old Mar 2, 2013 | 03:24 PM
Mxmeac's Avatar
Any other problems do u think?...
Old Mar 2, 2013 | 09:14 PM
Starter problems can be difficult to separate from bad battery, bad battery connections, or bad battery cables. All of these should be checked carefully.
Old Mar 3, 2013 | 09:04 AM
Roader's Avatar
This is the 4th starter, and still under 100k...The starter spins but didnt engage to the crank/fly wheel in order to turn the engine over. The new starter does the same thing. After the 2-3 attempt the car will start and run perfect...Im not sure if the fly wheel could be missing teeth.
Has the ring gear been checked for missing teeth? I'm not familiar with K-series engines but on most cars the flywheel or torque converter ring gear teeth can be viewed pretty easily with the starter removed, turning the engine by hand to view the entire circumference.
Old Mar 3, 2013 | 01:39 PM
Mxmeac's Avatar
Could there be another problem?
Old Mar 3, 2013 | 03:05 PM
Some parts stores can test the battery, alternator, and starter. They hook up their tester to the car and takes little time.
I remember I had this done once and they said my starter was not getting enough power. It wasn't too long before I was replacing the contacts for the solenoid.
Old Mar 3, 2013 | 03:06 PM
Croft's Avatar
All the relay does is supply battery to the starter. If it cranks then it is not likely the relay. I had a starter/flooding issue in my 89 Accord that resolved itself when I replaced the battery. I thought the battery was good. Check the voltage, it is an easy check with a $15 meter from Harbor Freight.
Old Mar 15, 2013 | 08:54 AM
  #17
Mxmeac's Avatar
So i was using " remy" brand starters, thats why it would not work correctly. I tried a different brand, and it works.
Old Feb 21, 2014 | 03:02 PM
  #18
Mxmeac's Avatar
Not sure what the brand is, but 1 almost 1 year and it's acting up again..
Old Feb 21, 2014 | 03:03 PM
  #19
Mxmeac's Avatar
I lightly hit the starter with a hammer and it worked, and I started the car like 15x now and no problems... The starter in now is a lifetime replacement... We'll see
BrenMc23
Feb 19, 2015 11:28 AM
tony_toca
Feb 4, 2011 10:10 AM
meme92
Jan 10, 2011 03:06 PM
oufy
Oct 31, 2006 12:02 AM
dude9571
Feb 12, 2006 07:32 PM
