Starter problems associated wit the a/c 2007 Accord LX
Old Nov 8, 2020 | 09:51 AM
dannyo's Avatar
Default Starter problems associated wit the a/c 2007 Accord LX
My daughter has a 2007 Accord LX 4 cylinder and if her a/c is left in the on position and she attempts to start the car, it will not crank. She can put the a/c in the off position and the car starts just fine. While driving, if she turns the a/c on, then the car has a jerking pattern like it is under powered.
This started about 6 months or so ago and she had the battery replaced. That seemed to have fixed the problem until now, as it has started having the same issues.
Does anyone have a permanent solution that could be shared?
Old Nov 8, 2020 | 12:47 PM
Seanjordan20's Avatar
Yes the alternator. Have it checked out to make sure it's not on its last leg. If you have a power issue like this always get battery and alternator test. Initially it probably was your alternator under providing power and putting a new battery in helped extend the inevitable.
Old Nov 8, 2020 | 06:42 PM
dannyo's Avatar
Default Thanks for the info!
I will have her get it checked. This is good news!! Thank you!
thisguy80
Apr 17, 2015 03:43 PM
brs7024
Dec 1, 2011 05:20 AM
ihadiyanto
May 12, 2010 02:43 PM
wolfehunter
Mar 12, 2010 09:16 PM
theycallmerickjames
Jul 4, 2007 03:55 AM
