Starting Issue - 2004 Accord V6
Old May 20, 2017 | 09:49 AM
richhastings's Avatar
Default Starting Issue - 2004 Accord V6
Need a little help diagnosing my Mother's 2004 V6 Accord.
Video links of starting issue.
Video 1:
https://goo.gl/photos/FkpAL7yr95Uje6X67
Video 2: Starting attemt when Tapping on starter
https://goo.gl/photos/XXh3dgA3gsBkxzn48
Diagnoisis/Testing Info:
Battery is less than 1 year old.
Battery cold Voltage is good. ~12.6
Alternator: When car was last running, it produced voltage over 14V, appears good.
To try to elminate the battery, I put the battery on a charger, and attempts above were with connected charger.
Could this be the starter? I attempted tapping on starter, to see if there was a dead spot.
The car will not start at all now. Last night, it still had issues but was able to start. First try, it would turn a few over for a brief period before stopping. Then second try it would catch after only turning over for a short period. Today, it will not start at all.
Any suggestions?
Old May 20, 2017 | 03:02 PM
Default Update - Starting
With additional troubleshooting: I continuined to hold the key in starting position. It turned over for a second, paused for a second, turned over for a second, pause for a second....
Video of attempted start with prolonged key enaged in start position:
https://goo.gl/photos/LiEzgyCUMWZXvGPW7
I was eventually able to get it to start, after prolonged key engaged. Here is a video of it eventually starting:
https://goo.gl/photos/8ec7qBG96g6bGtag8
Could this be:
* Ignition switch?
* Bad wiring connection?
* Would a bad starter behave this way?
Old May 20, 2017 | 05:07 PM
It could be all 3 of those items.
You should eliminate the wiring and the signal from the ignition switch before replacing the starter.
Use a volt meter on the small wire to the starter. That wire should get around 12V when you turn the key to start the car.
If you have room, you can use a jumper cable from the + battery post to the where the big wire connects to the starter. Connect the jumper to the starter first, make sure you are only touching the post and not anything else, then connect the jumper to the + battery cable.
If the starter is bad, I've used Denso starters or had them rebuilt locally. You run the risk of poor quality from the starters you get from the parts stores. You could get a new one from Honda, but they are expensive, so I usually go with Denso aftermarket (who made the Honda starters).
Old May 21, 2017 | 01:53 PM
Default Test Results
Starter wire test:
I did a voltage test to the small wire. I had user turn and hold the key in the starter/crank position. The wire got a constant 12.4V. So I assume that this would eliminate the ignition switch?
Jumper cable test:
I jumped with jumper cable from the positive of battery to the starter, positve pole. Attempted staring. There was no change.
So, does this only leave the starter as the cause?
Old May 21, 2017 | 04:05 PM
That just leaves the starter as the problem.
Old May 21, 2017 | 09:15 PM
Default Conclusion
Thank you for your help. I did take the starter in today. It failed the bench test. I installed a new starter, and it resolved the issue.
Old May 21, 2017 | 09:30 PM
Too often people will replace a part and still not resolve the problem, or we don't find out the results.
Thanks for doing all the suggested testing and for posting the outcome.
Milooo
Jan 26, 2023 06:09 PM
brar
Jan 23, 2012 12:28 PM
mmrwillib
Sep 1, 2011 06:55 PM
jacks132
Sep 2, 2009 10:28 AM
RDX
Feb 1, 2008 05:15 PM
