starting issues
Old Nov 11, 2012 | 07:46 PM
Timothy Stucki's Avatar
Default starting issues
Honda accord LXI 1989. The battery holds a charge and the alternator is fine as well i tested both I'm not sure if its the charge back wire or the after market stereo causing the car to not start on occasion. Please let me know of anything I can do to fix this issue.
Old Nov 12, 2012 | 07:10 AM
When it doesn't start, does the starter fail to spin the engine (starter problem)?
Or does it crank but not fire? (fuel or spark problem)
Old Nov 12, 2012 | 05:56 PM
Check and verify that you are getting 12v on the small wire to the starter when the starter fails to spin the engine over.
Also be sure the ends of the cables on the battery are clean and tight. Then check the ground cable where it attaches to the body and then to the trans to be sure those connections are clean and tight.
Last edited by poorman212; Nov 12, 2012 at 06:29 PM. Reason: moved another post out of this thread
Slowaccord
Aug 28, 2007 08:38 AM
sir_nasty
Feb 7, 2007 04:19 PM
MRMASON
Oct 3, 2006 07:09 PM
brad6841
May 22, 2006 09:38 AM
brad6841
Apr 13, 2006 06:20 AM
