Static when rear defrost is on - Control box?
Old Jan 2, 2013 | 01:46 PM
TeeJayEX-L's Avatar
Default Static when rear defrost is on - Control box?
I read an older thread trying to address the problem with static on the radio when the rear defrost is on. It mentioned to replace the control box behind the left C-pillar. I'm not really sure where to get that part, or how to access it. Anyone had the same issue that they've resolved without replacing the control box? Or is it an easy fix that I can do myself?
Old Jan 2, 2013 | 02:30 PM
What year is your car, number of cylinders, etc.? You may want to include in your signature so we don't have to ask.
Old Jan 2, 2013 | 02:52 PM
Also, sedan or coupe?
Old Jan 2, 2013 | 02:54 PM
TeeJayEX-L's Avatar
I have a 2007 EX-L, 3.0L, 6-speed transmission. Sedan
Old Jan 2, 2013 | 03:02 PM
Do you know if the car has side curtain air bags?
Old Jan 2, 2013 | 03:04 PM
TeeJayEX-L's Avatar
Yes it does.
Old Jan 2, 2013 | 03:47 PM
The other thread probably is referring to the window antennae coil.
The following is for information only for some of the steps required and having a qualified technician perform the work is recommended.
Instructions to remove the C-Pillar and seat side bolster. Since the car has side air-bags, the negative battery cable should be disconnected and a wait of at least 3 minutes is necessary.
C-Pillar removal
Rear seat removal
Attached Thumbnails Static when rear defrost is on - Control box?-window-antenna-coil.jpg
ughcord
Feb 22, 2009 07:50 PM
honda123
Nov 13, 2006 05:25 PM
honda123
Nov 13, 2006 02:08 PM
Spatula
Nov 1, 2006 12:10 AM
