Steam comming from plastic Radiator top up bottle
Old Sep 22, 2010 | 02:00 PM
desfam5's Avatar
Default Steam comming from plastic Radiator top up bottle
Honda accord 1990 lx
Hello,
I replaced the thermostat on my honda, and now I have steam coming out of the plastic bottle that hold the radiator cooling fluid, that is to the left of the radiator. What should I do?
Old Sep 22, 2010 | 05:45 PM
When you changed the t-stat did you bleed the cooling system?
Make sure the rad is full, ONLY check/remove the cap when it is cold. Once it is full, re-bleed the system.
Then I have to ask, you replaced the t-stat for some reason. So this was not happening before the change, correct?
Old Sep 22, 2010 | 08:21 PM
desfam5's Avatar
Default how do i bleed the system?
I loosen the 12 mm bleed nut located near the t-stat. Do i bleed with the engine off or engine running? what is the correct bleed procedure, step by step
Old Sep 22, 2010 | 11:56 PM
deserthonda's Avatar
engine off,,,,,,,,,loosen the 12mm nipple,, add coolant ( 50-50 mix ) till no air comes out, once only coolant flows, tighten the nipple, fill radiator to top, install cap , start car up,, Also chk the cap make sure that it is ok, BOTH ,fans working ok ?? t-stat opening up ok ??lower hose almost as hot as top hose ??
aloha_bruddah
Aug 21, 2014 01:39 PM
ghostpilot
Mar 8, 2012 12:04 AM
mjhenks
Feb 11, 2010 07:40 AM
restrict187
May 20, 2007 08:23 AM
thunder_x
Oct 18, 2006 10:56 PM
