steering noise/problem
Old Sep 27, 2006 | 11:33 PM
anders777
Default steering noise/problem
hi i have an 06 accord v6 sedan, and i have had it for about 9 months. About a week ago, i took it on some canyon roads and made some sharp turns. Now, when i back up while turning the steering wheel, about half way, i hear a "thunk" sound, as if something near the steering or the axle snapped. I can even feel it on my floorboard. This also occurs when i take turns at higher speeds going in drive. It would be much appreciated if i can understand what the problem is, or if it is even a problem at all. Thank you for your time
Old Sep 28, 2006 | 01:46 AM
deserthonda's Avatar
Default RE: steering noise/problem
First off Welcome to HAF,,,,
it is nNOT NORMAL to hear a thump noise from under the car at turns,,
my best advice is to raise the car, remove the wheel on the side you hear the noise from and chk for loose or broken suspension parts...
it could be the sway bar link i have seen a few of those on earlier year models ..
Slusher's Avatar
Hopefully your car is still under warrantee, I'd just bring it in to the dealership. You might have a steering rack/tie rod/ball joint/strut/sway bar issue, but I'm just guessing. Do you feel it in the steering wheel? How many miles are on your car? Any difference in the way your car handles?
amajakgar
Aug 9, 2014 09:22 AM
loki16
Aug 12, 2013 06:54 AM
darkgreen18290
Jun 25, 2013 07:51 AM
mrscotty
Dec 11, 2007 08:00 PM
