NEED ADIVCE PLEASE!
Old Sep 18, 2006 | 01:31 PM
launch890
Default NEED ADIVCE PLEASE!
i have a 95 honda accord with a v tec engine and i have a problem. the car has a loud rumble at low speeds and runs like crap when the c/a is on and often stalls when i come to a stop with it on. alwo the brake depressurises itself after i come to a stop, often leaving my car moving again. then when i do press the brake pedal to the ground it will either give me a louder rumble or smothe out for a few seconds depending on if the car is running more smothly or choppy that day, respectivly to the problems. i was wondering if this could be a vaccum leak somewhere causing all of this. if some one could help me out with some ideas i would realy apreciate it.
Old Sep 18, 2006 | 04:21 PM
Slusher's Avatar
Default RE: NEED ADIVCE PLEASE!
Not too sure about your rumble but your brake problem sounds like the brake master cylinder. I take it you're not losing any brake fluid or anything like that? Yeah brake master cylinder, mine did the same thing.
Old Sep 18, 2006 | 04:28 PM
sir_nasty's Avatar
I'd agree that it sounds like a master cylinder problem for your brake issue (providing your brake fluid is full), as for the stalling issue does your car idle up when you turn on the a/c? Does it run fine with the a/c off?
Old Sep 26, 2006 | 03:16 AM
launch890
yea it idles up, but it runs batter with it off, but it still runs badly and is very choppy
Old Sep 26, 2006 | 05:25 AM
Slusher's Avatar
I would do a search on here for 'cleaning TBI'. I have not had to do it myself but from what others have said it sometimes can cure a crappy idle. Check it out and let us know if it helps. Also, what does your car idle at?
Old Sep 26, 2006 | 01:02 PM
hondadude's Avatar
If you are at idle in neutral and step on the brakes, the idle dips way low or stalls; you need to start looking for a vacum leak.
The reason is the brake booster uses a large volume of vacum and then if there is a vacum leak the engine suffers.
Might be a problem at the A/C idle boost, does the RPM increase when you turn on the A/C ??
Old Sep 26, 2006 | 01:28 PM
sir_nasty's Avatar
ORIGINAL: launch890
good idea on the neutral test... I was of the same opinion as you though... sounds like a low idle issue and a bad master cylinder.... but diagnose before you start replacing crap...
Old Sep 28, 2006 | 04:33 AM
launch890
how do i look for a vaccum leak? and also could it be the IACV?
99accordf23a5
May 6, 2014 12:51 AM
esan805
Mar 29, 2012 02:33 PM
art vandelay
Aug 2, 2010 09:29 AM
BIGWILBO
Apr 5, 2008 07:57 PM
ryan ortego
May 19, 2005 06:06 PM
