Steering wheel pulls on acceleration
Old Oct 15, 2006 | 03:40 AM
YeuEmMaiMai's Avatar
Default RE: Steering wheel pulls on acceleration
it's a I4 right?
MY 94 would pull under WOT and I believe that it had to do with the tires on the car because once I replaced them with tires that were slightly better the pull was not nearly as bad.....
ahah reason my '98 accord did not pull has to do with the fact that the j30a used in that generation of car has absolutely NO LOW END GRUNT
CL type S does not do it since VSA pretty much eliminates it. TURN VSA OFF and it is whole different story.......
Old Oct 15, 2006 | 11:45 PM
Alekat's Avatar
Front AND rear tire pressure is important.
Also - the right side is the short shaft. If the left side CV joint(s) are worn - this could cause the short shaft side to have more control.
Old Oct 16, 2006 | 01:34 AM
deserthonda's Avatar
ORIGINAL: Alekat
totally untrue
99NYACCORD
Jul 12, 2013 05:26 PM
accordfan
Jun 13, 2011 10:35 PM
Road Head
Nov 23, 2006 02:00 AM
nedpoins
Jan 6, 2006 07:13 PM
