Stereo install - simple Q
Old Jul 7, 2008 | 03:23 PM
atarikid07's Avatar
Default Stereo install - simple Q
I've looked up the DIY on this, but I've just got one question.
If you look here:
http://www.installdr.com/InstallDocs...PDF/466053.pdf
On page 5 it lists a bunch of steps. Are these there, in case you don't buy the aftermarket wire harness? In other words, are the things on pgs. 5 and 6 irrelevant, unless you want to splice your own wires? Or is there an extra bit of information I am overlooking?
Also, is taking the dash cover and clock off easy? I dont want to break anything...
Old Jul 7, 2008 | 08:04 PM
atarikid07's Avatar
Default RE: Stereo install - simple Q
Ok, so I got it installed. Now, I have a new problem though. After the installation, I noticed that my backlights to my clock and odometer don't work. How is it possible that this happened? And how do I fix this?
Old Jul 8, 2008 | 08:11 AM
falkore24's Avatar
Check to see that you didn't blow a fuse during the install.
Old Jul 8, 2008 | 08:45 AM
Asmir02
Same thing happened to me! I check all the fuse they all work, I even try pluging back in my old factory radio and still doesn't work! I have the same car too.
Old Jul 8, 2008 | 12:42 PM
Asmir02
I found out the problem it was multiplex control unit driver side soo i got another one from honda parts it cost me $75 and friendreplaced it and now everything works fine. Make sure you get a driver side multiplex control unit.
open this up
http://www.driveaccord.net/forums/at...p;d=1196877500
read that and it will show you how to replace it.
Old Jul 8, 2008 | 01:01 PM
falkore24's Avatar
Diagnose everything that can be wrong BEFORE buying ANY parts for your car. There is no simple answer for all problems that seem alike.
Old Jul 8, 2008 | 10:59 PM
atarikid07's Avatar
It says on the pdf that this replacement should be done free of charge... How long do these recalls last for (assuming that my car falls under the VIN category)?
And what else could it be other than fuses? This has happened to me in the past, with the a/c strength dial backlight. That, however, fixed itself. Ideas?
EDIT:
I just realized that the recall only applies to LX Accord, not my EX. Wow, what a predicament.
Old Jul 9, 2008 | 08:35 AM
falkore24's Avatar
Did you check the fuses? There are 3 panels on your car.
Cobrajay
Oct 3, 2007 10:36 AM
drewdin
Jul 4, 2007 10:08 PM
jprez1980
Apr 3, 2007 02:57 PM
wcbzero
Mar 13, 2007 08:05 PM
SilverBlueVTEC
Jan 7, 2006 11:11 AM
