Stick wont shift
Old Sep 4, 2012 | 09:40 PM
firemanwill's Avatar
Default Stick wont shift
New clutch. New clutch hydralics. No shift. Big Problems.
Need Help!!!!
Old Sep 6, 2012 | 01:30 PM
Need a bit more of a description.
Old Sep 8, 2012 | 04:14 PM
I changed out my clutch and put the tranny back in. Can run thru the gears while car is off, but while the engine is running, the car wont shift into any gear. I shifted the car into gear and then cranked it and the car jumped and stalled. i then switched out the master and slave cylinders and still nothing.
Old Sep 8, 2012 | 11:21 PM
basket_case's Avatar
Did you bleed it really well? You might have some air in the system. I don't know about Accords, but Ford Ranger hydraulic clutches were notoriously hard to bleed and took a lot of effort to get them right.
Old Sep 10, 2012 | 09:13 AM
Have someone pump the clutch pedal while you watch the slave & throw-out lever. It should move about 12mm back & forth.
Another thought... I think I've heard of someone putting the clutch disk in backwards, so the clutch is always dragging even when the throwout lever is operated correctly. I don't really know how much difference there is one-side to the other; do you remember whether is was obvious when you assembled it?
consumed24
May 23, 2008 11:28 AM
sarmac415
Dec 15, 2007 02:09 AM
GalenMan679
Nov 12, 2007 05:05 PM
sir_nasty
Sep 25, 2007 08:22 PM
reeling
Aug 15, 2007 05:06 PM
