97 Accord Coolant Leak
Old Sep 9, 2012 | 05:55 PM
jerrym's Avatar
Almost A Senior Member
Wink 97 Accord Coolant Leak
While driving my 97 Accord today, the small hose from the manifold to the heater inlet valve started leaking, and most coolant was lost. Before I realized what was going on, the engine overheated and was acting sluggish and running rough.
The leak was right by the hose clamp under the distributor, so I was able to cut out the bad section and reinstall until I can get a new hose. Refilled the system with coolant, and no problems with engine temp while driving home.
Anyway my question is, since the engine got pretty hot should I perform any additional maintenance or checks?
Plan on changing the oil as a precaution. Any suggestions are appreciated.
Thanks!
Old Sep 9, 2012 | 08:25 PM
Dr. Drivability's Avatar
should be ok, but i always changed the t-stat when an engine overheated, oil change is a good idea. give the rest of the hoses a good inspection and put a new rad cap on it.
Old Sep 10, 2012 | 12:43 AM
AccorDats's Avatar
just to add:
is this an a/t? if it is, i would suggest to drain and fill the trans fluid too, or check for burnt smell.
Old Sep 10, 2012 | 09:16 AM
jerrym's Avatar
Question
Thanks for the info, and yes I'll changer out the AT fluid too. 3 qts is only about 25.00 or so. Did not know temperature can affect the radiator cap? I am thinking maybe due to the heat and the caps rubber seal?
Rob2000AccordLX
Jul 14, 2010 01:21 PM
6hhhh6
May 31, 2010 01:27 PM
demetrius
Feb 1, 2010 11:32 AM
tr7driver
Dec 1, 2008 12:00 PM
vlil
Jul 29, 2008 10:53 PM
