Still getting Scrap from my car
Old Apr 9, 2013 | 08:18 AM
  #71
RobinsonRicer's Avatar
Forgot to update this. Problem is solved it seems.
Ignition coil was the initial problem. I also replaced the wires with NGKs.
I suspect an issue with the alternator as I smell a burning smell from it but the battery is charging fine and the car will run on just the alternator.
But problems solved. Thanks for your advice and patience guys.
Old Apr 9, 2013 | 11:25 AM
  #72
Roader's Avatar
Good to know, especially considering "The issue started with the f23 manifold swap." Your troubleshooting persistence paid off. Internal or external coil? In either case, it must be that the coil was shorting when the engine got hot. A common failure 40 years ago but not too often seen in modern cars.
Old Apr 9, 2013 | 02:12 PM
  #73
I think internal. Inside the distributor cap.
That fix gave me a consistent and strong throttle. Now to move on to other small issues. And there are a few. This car just takes a beating.
snntuson
Jun 20, 2013 06:02 PM
steelworker
Nov 23, 2012 02:08 AM
hamann
Nov 3, 2008 02:56 PM
jastunna1987
Dec 22, 2007 04:15 PM
CasualObserver
Dec 14, 2006 02:06 AM
