stock radiator hose clamp or aftermarket
Old Jul 5, 2016 | 02:42 PM
CHUCKW's Avatar
Default stock radiator hose clamp or aftermarket
guys,
I had my radiator hoses replaced and the shop put on the screw type hose clamps. Is this ok or should I replace with Honda type clamps? I have heard that screw type can put too much pressure on the radiator neck and crack it.
Old Jul 5, 2016 | 03:08 PM
rockhoundrob's Avatar
I use the screw type. Just be careful about over tightening it. Better to have it slightly loose and it leaks a drop, then you know to tighten it just a bit more.
Old Jul 5, 2016 | 04:27 PM
Spring-clamps (like stock) can keep it tight as the rubber extrudes out from under the clamp. That's good for people who never ever open their engine compartment.
Screw clamps have to be tightened occasionally, when you notice a couple drops of coolant, maybe every few years (maybe never).
Old Jul 6, 2016 | 05:56 AM
dgp1961's Avatar
Almost A Senior Member
Screw type is fine as long as you don't break your hand tightening them. If your concerned just back it off and re-tighten yourself then you know how much pressure is on it. As stated maybe even go a little loose and watch for drips then tighten accordingly if that puts your mind at rest.
Old Jul 6, 2016 | 08:19 AM
CHUCKW's Avatar
Thanks for the input guys. Will keep an eye on them.
Old Jul 6, 2016 | 11:43 AM
brayner's Avatar
Yes, they should be fine. The spring loaded are better, especially in areas that get wide temperature variation. Rubber, steel, aluminum all expand and contract at different rates.
Thoughts- Many folks prefer screw type. The last large hose clamp I bought from Honda was like $13.50. Glad I only needed one (they rarely fail)
BlackLX4
Nov 26, 2015 03:45 PM
MessAround
Apr 13, 2014 09:21 AM
brandon0409
Jan 28, 2014 07:02 AM
jamesejam
Sep 21, 2009 02:37 PM
newwct
Sep 19, 2006 10:37 PM
