stopping on the way
Old May 2, 2013 | 04:15 PM
Rilex's Avatar
Default stopping on the way
hello all, today my accord 98, 4cylinders, auto trans will just suddenly goes off on the highway but the light stays on, I am thinking probably is the plugs and I have not use the car for a week now because i have second honda accord car i am using. Any suggestion on what might be responsible for these problems? Hoping to hear from you guys. Thanks
Old May 2, 2013 | 04:52 PM
shipo's Avatar
If I understand you correctly, the engine quits operating while on the highway; if so, then it isn't the spark plugs.
Have the OBD-II codes read at a car parts store to see if there are any fault codes which can help us diagnose the issue. Failing that I'm thinking this might be a heat related computer fault or a fuel delivery issue.
Old May 3, 2013 | 12:15 AM
Rilex's Avatar
thanks to you shipo, if it is a problem coming from the fuel delivery system. how do we correct this quickly? Because as i told you before i don't use the car too often. I will quickly give it to the mechanic to check it out before using it to travel today. Any further suggestion from you will be helpful. Thanks
Old May 3, 2013 | 08:16 AM
shipo's Avatar
Until the codes are read any further speculation would be just that, speculation. Your mechanic should be able to quickly determine if there are any codes or of there is a fuel delivery issue.
Keep us posted on how you make out.
Old May 6, 2013 | 05:14 PM
If there are no error codes stored, then it might be caused by a flaky ignition switch. Normally, that causes all the warning lamps to go dark also, because it is EXACTLY like you switched off the key. But a flaky switch might act ...well, flaky.
Old May 10, 2013 | 03:42 PM
Rilex's Avatar
I suspects is a flaky ignition switch because the next day the car didn't stop all the way and it droves smoothly. I was beginning to afraid that probably the fuel Injector is going bad or fuel pump. Any other things to lookout for such problems? Thanks
Old May 12, 2013 | 02:00 PM
Normally if a bad fuel pump stops, it won't re-start unless you hit the bottom of the fuel tank with your fist.
IF you can duplicate the problem by wiggling the key, that proves it. HOWEVER, if you can't get it to stall by wiggling the key, that DOES NOT prove the switch is good. You can remove the plastic shroud around the steering column & look for anything suspicious on the switch (burn marks?)
chgoss
Jul 23, 2012 09:25 AM
Jimmie Anderson
Feb 28, 2012 01:49 AM
du907
Nov 26, 2011 08:10 AM
BigB58
Jul 9, 2009 03:48 PM
Codonah
Jun 17, 2008 08:47 PM
