Strange Brake Indicator Problem
Old Aug 8, 2010 | 04:24 PM
ctconline's Avatar
Default Strange Brake Indicator Problem
After replacing the distributor, I was out test driving the car. I went to the store and everything was fine. On the way home, I noticed that the BRAKE indicator was lit, but the emergency brake wasn't on (I was driving). The funny thing about this issue is that when I pushed in the clutch to shift gears, the stupid indicator would go out. When I let the clutch out, it would come back on. WTH??
Old Aug 8, 2010 | 06:51 PM
Look behind the clutch pedal to see if any wires are being moved when you push in the clutch.
Old Aug 8, 2010 | 07:26 PM
Also check your brake pedal switch and replace if it needs to be replaced.
Check its wireing also.
Old Aug 8, 2010 | 10:28 PM
deserthonda's Avatar
also chk the brake fluid in the reservoir make sure that it is full
boksh928
Oct 21, 2009 11:55 AM
FUBAR
Nov 25, 2008 04:43 PM
2003 V6
Jul 16, 2008 08:02 AM
2003 V6
Jul 6, 2008 10:16 AM
Uber
Dec 19, 2007 02:34 PM
