Stripped threads on head for valve cover
Old Nov 22, 2023 | 12:40 AM
Ihavnoclu_2's Avatar
Default Stripped threads on head for valve cover
Hey all, new to this forum. Basically I was replacing the valve cover gasket on my 1996 Honda accord (2.2L 4cyl vtech)because it was leaking, and as I was putting the bolts back into the block one of them suddenly went righty loosy. Now this wouldn’t have been that big of a deal cause I could have just slapped a heli-coil into it and been in my mary way, however it just so happened to be my luck that it was already heli-coiled. Would I be able the just put two heli-coils together so that after I re-drill and tap it is back to the original size or is there a better option?
TLDR; head was already heli-coiled, and the block got stripped when re-installing the valve cover… not sure what to do
Old Nov 22, 2023 | 11:19 AM
I probably wouldn't put two helicoils together to fix this kind of problem. I'd probably remove the valve cover and insert the bolt into the cylinder head to see if the entire helicoil is spinning or if the inside threads are messed up to determine an appropriate plan.
Old Nov 22, 2023 | 11:41 AM
The heli-coil bunched up on the bolt and stripped the head out
Tj Millinder
Nov 11, 2019 05:57 PM
Al S
Nov 26, 2012 07:28 PM
JasonSater
Oct 6, 2012 03:57 PM
james2oo8
Feb 17, 2011 06:48 PM
HondaAccordEX94
Apr 5, 2010 04:27 PM
