Stupid question.. Stick shift, how to check fluids..
Old Dec 23, 2011 | 09:00 PM
93Accord2.2's Avatar
Maybe they were talking about an AT accord, then?
I can't believe engine oil goes into a manual transmission.. that's kind of funny
Since it takes engine oil, which lucas additive would I use, the one for transmissions or the one for engine oil??
Old Dec 24, 2011 | 09:11 AM
Yes they were talking about an auto.
Personally I would use the MTF from Honda, which is an upgrade from the engine oil.....
Old Dec 24, 2011 | 02:27 PM
joec44's Avatar
Poor man is rite on! Go to a honda store get the 2 rings for the drain and fill plugs als get 3 Qt. honda MTF jack it up leavel drain it put the new rings on put botem plug in use a funnel and a long hose to fiil it from top any thing other than honda MTF can cause a problem IMO
Old Dec 24, 2011 | 02:51 PM
UhOh's Avatar
took the time to photo, upload, link and show you from the Bible.
OK, 93Accord, you owe me. PM me your location, so when I drive thru there you can buy us a pitcher ...
All said , Honda Man Trans Fluid (MTF) has gotta be good.
I said it takes 2.5 qts, by memory, but this corrects my memory which was off by 1/2 qt...
Fluid viscosity ranges
and how to check it...
Old Dec 24, 2011 | 03:05 PM
UhOh's Avatar
Originally Posted by UhOh
A fill plug, socket not fit; all fluid goes in here - until it dribbles out.
Fill plug has a negative 4 sided hole that the ratchet itself fits into, no sockets.
can't recall what this is called - dumb me, help.
also possible memory wrong here since I also have a Nissan MT and I could be confustigated between the brands...
Old Dec 24, 2011 | 04:31 PM
You guys are beautiful .. Thanks
Old Dec 24, 2011 | 05:19 PM
  #17
Changing out all of the fluid from a manual transmission is simple. Just drain and refill, like engine oil. Refilling is a bit of a pain, because the fill hole is low and on the side of the transmission. I filled from the top with a funnel and a long hose that I stuck into the fill hole.
Changing out all of the fluid on an automatic is a bit more complicated, because a lot of fluid stays in the torque converter.
Old Dec 25, 2011 | 06:46 AM
  #18
When I change my oil I always pour a fresh quart through to get rid of what is left in the pan or even fill it up with fresh oil and run it awhile and drain it again .. I don't imagine that is necessary and is probably complete overkill for the transmission, right? And there's no filter to worry about?
Looking forward to having the money and space to get some things done on this car..
Old Dec 25, 2011 | 08:26 AM
  #19
Up to you, whatever gives you peace of mind.....we all have things like that.
No filter to worry about.
Old Dec 25, 2011 | 08:02 PM
  #20
UhOh's Avatar
PM to 93accord
also, let us know how your experienced female driver likes the 'feel' of the new tranny oil,
in whatever flavor you choose, with the Lucas additive.
consumed24
May 23, 2008 11:28 AM
sarmac415
Dec 15, 2007 02:09 AM
GalenMan679
Nov 12, 2007 05:05 PM
sir_nasty
Sep 25, 2007 08:22 PM
reeling
Aug 15, 2007 05:06 PM
