Stuttering and missing at partial throttle
Old Jan 21, 2007 | 06:21 PM
greenete's Avatar
Default Stuttering and missing at partial throttle
I hope someone out there can help. I have a 1994 Accord EX with manual transand V-Tech engine. It's been running great for the last year, then all of a sudden it's developed a bad miss and stuttering at partial throttle from just above idle to about 3000 rpm. It sounds like it runs on only 2 or 3 cylinders. It idles great at about 800 rpm, and at 3/4 to full throttle it is smooth and has great accelleration. The problem is only at lower rpms atpartial throttle. It actually runs better when you run it harder, but at steady throttle at 60 mph in 5th gear, it is bucking and missing. I changed the plugs and it made no difference. If it had a carb instead of fuel injection, I would say it had some dirty passages in the idle circuit. I'm thinking it's something with the IAC or something related to the idle circuit. I've checked for loose connections and vacuum leaks, but everything looks OK. Any suggestions or similar problems out there??
Old Jan 21, 2007 | 08:23 PM
hondadude's Avatar
Default RE: Stuttering and missing at partial throttle
To test for EGR problems have the engine fully warmed up then 'powerbrake' till you get the RPM up past 1500-1700. If you feel the enginestumble, click up the link below.
http://members.troublecodes.net/hond...5AccordEGR.htm
Old Jan 21, 2007 | 09:37 PM
poser_pilot6
Yeah, that sounds a lot like EGR ports. Thats pretty much what my car was doing until I gave the EGR ports and valve a thorough cleansing.
sistar
Sep 22, 2013 10:44 PM
Daisy Lily
Feb 20, 2013 11:50 AM
mitbrown
Dec 25, 2011 08:06 AM
HondaPerson
Mar 26, 2011 05:46 PM
HondaPerson
Mar 22, 2011 10:32 AM
