Sudden drop of fuel consumption
Old Jan 11, 2013 | 07:07 PM
Eugene Eliseev's Avatar
Angry Sudden drop of fuel consumption
Hi
I have 2009 Honda Accord V6 (59k). For all 3 years I owed it the fuel consumption was about 24 mpg (city mostly).
Two weeks ago it dropped to 12.6 mpg. No check engine light is on. I use the same gas station. Air filter was changed in October. Tire pressure is normal. Car is running the same way. What can be a problem?
Old Jan 11, 2013 | 09:26 PM
Check for brakes dragging? I don't know your mechanical abilities, whether you want to remove the wheels...? Or check another way.
Flat empty parking lot. Get the car moving at barely walking-speed. Put the transmission in neutral (or press down the clutch pedal if it's manual). It should coast smoothly.
You'll notice dragging brakes by the sudden grabbing at the very end of coasting to a stop. If you're not sure what it feels like, try again but rest your foot lightly on the brake pedal.
2009 is kinda new to be worried about a fuel leak from corrosion, but I guess it's always possible to damage a fuel line if something hits it under the car while you're driving. I don't know where you're located, but in wintertime it's not always easy to smell the leaking fuel.
darkgreen18290
Sep 8, 2014 06:24 AM
Fasteddy_98
Dec 21, 2012 12:58 PM
diddly
Aug 8, 2010 06:27 PM
sssexy70
Feb 10, 2007 05:43 AM
pascha
Jan 30, 2007 03:58 PM
