Sunroof leaking
I just purchased a '92 EX Coupe. The seller told me the floor gets wet when it sits in the rain. It was, and still will spend most of its time in the garage, but I want to address the problem. I know leaks are usually from plugged sunroof drains. I checked the forums for any posts, but it didn't return anything that would help me. The water is leaking in the drivers rear, the drivers side back seat floor gets wet, and I'm getting water in the drivers side of the trunk. Thanks in advance for the help !
I haven't had any problems w/ my Accord sunroof, but have on other models. I opened the sunroof and poured water into drain channel and watch drains (near wheel well) for drainage. Two possibilities; drain is plugged or loose from sunroof drain outlet. You may have to drop the overhead liner to accss the drain tube if it's come loose. I had to do that on a Toyota Celica. Somehow the drain hose separated from the nipple drain outlet.
Looks straightforward, but you need the manual to guide you. Download a manual from DIY section Online Links post. Either 91-93 Accord is probably same for headliner.
