suspension/brake help
Old Sep 30, 2010 | 10:01 PM
accord1994's Avatar
Default suspension/brake help
I have a 94 accord that I need some help on. First time on this forum. I have my accord for 10 years now, 250,XXXmiles and still going. Its been good to me but now just some problems with the brake/suspension. When running over little pot holes, bumps, rough streets, its making some noises, sound like the suspension is loose somewhere. But when I tap the brakes running over the rough streets it doesnt make those noise. I just recent got all four new brake calipers, brake pads, and rotors installed. All new ball joints and tie rods. Ive checked all the suspension and nothing is loose while the car is on jackstands. Before I put all these new parts in..... the car was already having this problem. Now i just need some help on this situation. Thanks in advanced.
Old Oct 1, 2010 | 01:29 AM
I would look at the rubber bushing where the shocks bolt to the lower control arm. Also look at the anti-sway bar end links for signs of wear on the rubber bushings. There are also bushing on the radius rod that may be loose?
Old Oct 1, 2010 | 10:14 AM
accord1994's Avatar
I changed the end link and bushing not too long ago cause it making some squeeking noise, that went away. The bushing where the shock bolt goes is wornt out but would this explain why when i tap on the brake over bumps dont make that sound like its loose somewhere. Probally gonna have to change all those bushing and see if thats the problem.
mamtsberg
Mar 17, 2010 09:15 PM
bustum
Aug 27, 2007 06:38 PM
98accord98
Sep 8, 2006 01:25 AM
MR.97ACCORD
Apr 12, 2006 01:12 PM
George Knighton
Jan 11, 2006 08:49 PM
