Switch to Synthetic Oil?
Old Apr 22, 2009 | 11:43 AM
Jeff247's Avatar
Default Switch to Synthetic Oil?
I have a 2003 Honda Accord 4 cyl with 212,000 miles on it. No problems at all, just normal maintenance. Any problem switching to synthetic motor oil? Good idea? Thanks for you suggestions.
Old Apr 22, 2009 | 12:01 PM
Why mess with a good thing? The K-engine doesn't abuse the oil, overheating the oil like a turbo, or anything else.
I don't use synthetic oil in my non-turbo cars, because the longer oil-change intervals don't really pay off against the higher-priced oil. (Someday that will probably change as petroleum gets more expensive.)
I use synthetic in the turbos (2001 & 2005 Saabs) because the higher temperatures in the turbo spool contribute to sludge formation.
Old Apr 22, 2009 | 12:04 PM
craddock01
I've got a 1990 accord 230,000 been using Wal-Mart SuperTech Full Synthetic for a couple of years. $15.00 for 5 Quart Bottle.Good Stuff. Would like to add also this oil does not claim to be extended change,But at that price I like it,5k to 6k at drain and oil will not be broke down like Nonsynthetic.
Old Apr 22, 2009 | 05:25 PM
Jeff247's Avatar
Default Sounds good to me!!
I thought so to. I do the oil changes at 3-4000 and enjoy keeping an eye on things. And like you said, "Why mess with a good thing?" I keep having friends say "why don't you run synthetic, blah, blah, blah." Like I'm abusing my car. And I try my best to take care of it. Thanks.
Old Apr 22, 2009 | 05:39 PM
mejim707's Avatar
I jut switched to synthetic oil in my Accord last night. What I've read, and heard from others, the oil has cleaning properties that will d-gunk the inside of the engine without having to add additives to the the engine in hopes of achieving the same outcome. Over time, using synthetic oil you should see a difference on your oil changes. You'll notice that the oil comes out cleaner than it would with standard oil and yes, you can wait longer between changes, but, why? Change it still on your normal intervals and at least you know it hasn't broken down like the standard oil would. Oil break down = engine wear. I would much rather the oil be about as clean and useful coming out of the engine as it was going in.
Old Apr 22, 2009 | 05:53 PM
finch13's Avatar
Synthetic breaks down too, otherwise you wouldn't have to change it ever. It breaks down a lot slower than dino oil.
I change my Mobil1 at 5k miles and I can still see through it usually.
Changing synthetic earlier than you need to is just draining your pocket. It will provide decent protection past 7,500 miles.
Old Apr 22, 2009 | 06:04 PM
mejim707's Avatar
Very true that synthetic breaks down. Personally I would rather be on the safe side and change every 3-4 G and drain clean synthetic than change every 3-4 G and drain filthy broken down standard oil. Just a personal preference now. And yes, it's a little more loot but if you do it yourself and not go to Jiffy lube to have them do it, it's a lot cheaper and you know it's done right with the brand of your choosing.
Old Apr 22, 2009 | 06:36 PM
Jeff247's Avatar
Default Now I am leaning the other way!!!
I don't mind the esxpense as long as I think I am getting something. Generally speaking, does it matter if you switch after using it for 212K miles? Would if I decided to switch back after a few changes? Like I said, it runs great and always has. Like JimB says, "If it ain't broke...". Thanks for the inputs.
Old Apr 22, 2009 | 07:45 PM
bigdawg74's Avatar
I have read that folks who switched to syn after having lots of miles already on the engine have developed leaks. Apparently the molecules of syn oil are universally small compared to dino oil which vary (somewhat) in size. Maybe others here in the forum can chime in on this, but this is what I have heard.
Old Apr 22, 2009 | 08:11 PM
g22cd5's Avatar
Supper Moderator
For the price I use mobil 1 clean 5000 its cheep and a good name brand oil. It cost me around $15 w/ filter a oil change but I also change it ever 2-3k miles dew to high millage. They guarantee you dont have to change the oil for 5k miles
