tach acting crazy
Old Jan 9, 2013 | 08:11 PM
snicrep's Avatar
Default tach acting crazy
i have a 96 2.7 auto. when going hwy speeds the needle fluctuates wildly. it seems ok at slower speeds. what would cause this?
Old Jan 9, 2013 | 09:31 PM
When the tachometer is acting crazy, is the engine actually running at normal rpm?
Old Jan 9, 2013 | 11:42 PM
snicrep's Avatar
engine feels even. the tach swings from 2000-3500 constantly. when I stop or go much slower it behaves normally. I was wondering if it some kind of sensor going out on the tranny.
Old Jan 10, 2013 | 07:04 PM
The tach gets the "signal" from the ICM...at least in the 4 cyl 5th gen, the 6 cyl might be different.
If the engine is even and it is just the tach...there might be something with the wires or the drive circuit.
What do you know about the history of this car?
Old Jan 10, 2013 | 07:45 PM
The V6 is different. The tach gets it's engine speed output signal from the coil.
Old Jan 10, 2013 | 08:27 PM
Difficult to test for, so you rule out everything else (like flaky wiring connections) then replace the coil. I'll try to find an old thread about that.
Old Jan 10, 2013 | 11:27 PM
snicrep's Avatar
one new development...i drove it today but it was dry out, no problems. it was raining when it was acting up. i need to chk the connection. The car is a salvage title so it was in a wreck before i got it.
Old Jan 11, 2013 | 07:20 AM
I'd be looking for flaky wiring connections, anywhere. Maybe RedBull has enough drawings to point out the ground connections that are related to the tach circuit. Ground points are suspicious for corrosion.
I don't know where G404 is physically located, but also check the tach-signal wires coming off the coil. If the collision was anywhere near the interior fusebox, there might be loose connections there.
Gonna be a tedious job to check all that.
Old Jan 11, 2013 | 07:37 AM
Here's the location of ground G404. It is behind the front console (center area).
Old Jan 11, 2013 | 08:07 AM
hondadude's Avatar
The clue about the wet weather leads me to believe the coil is starting to short out.
Use a spray bottle to mist around the plug wires and coil area, then run the car and look for little arcs.
hank97
Aug 31, 2014 10:30 PM
husrddy76
Jan 26, 2010 07:24 PM
Julian91
Jul 26, 2006 12:41 AM
96AccordEXV6
Jul 18, 2006 11:27 PM
phaders
Jan 5, 2006 05:17 PM
