tach is messin up
Old Apr 4, 2009 | 11:09 AM
90exaccord
Default tach is messin up
i have a 90 ex accord. while driving the tach will go from 2200rpms and jump to 4200 rpms and it wont budge from there unless i go over 4200 rpms or if i go under 2200 rpms. Any ideas?
Old Apr 4, 2009 | 07:57 PM
Tach problems can be caused by bad spark plugs, ignition wires, coil, or ignitor. If you're having any drivability issues, ignition system needs careful inspection and repair.
If ignition system is working fine and tach misbehaves, the tach movement or instrument panel electronics are the problem. You can pull and replace w/ used or have yours repaired (google for repair sources).
96AccordEXV6
Jul 18, 2006 11:27 PM
iridebmx33
Apr 6, 2006 01:41 AM
brownstreak
Jan 8, 2006 03:19 AM
badmrb
Dec 6, 2005 03:16 PM
jayhova804
Jun 10, 2005 01:24 PM
