90 accord ex tach problem?
Old Dec 23, 2005 | 05:03 AM
brownstreak's Avatar
Default 90 accord ex tach problem?
I bought this accord a month ago and changed the speed sensor because the spedometer didn't work but the tach is still fliping out of control as soon as I rev past 3 1/2k. is it due to frail wires or the coil or something else? Im clueless
Thanks
Matt[:@]
Old Dec 23, 2005 | 01:29 PM
deserthonda's Avatar
Default RE: 90 accord ex tach problem?
remove the distr cap, in the ignitor there is a blue wire make sure it is not loose .....if it is ok. than u have to test the rpm signal on that wire outside of the distributor just plug into the wire ..if signal is ok at wire you might have a bad tach gauge
Old Dec 23, 2005 | 03:02 PM
Default will do
Ill give it a shot thanks.
Old Jan 8, 2006 | 03:19 AM
I turns out that the negative lead from the coil wasn't connected all the way and was touching at random I connected it back and the tach works great and the car runs a little smoother too. Thanks
live2rice
Jun 20, 2008 03:52 PM
james.walters
Mar 13, 2007 04:43 PM
bushy74
Feb 28, 2007 07:06 PM
iridebmx33
Apr 6, 2006 01:41 AM
badmrb
Dec 6, 2005 03:16 PM
