Tach quit working
Old Jul 3, 2008 | 07:38 PM
dacecil's Avatar
Default Tach quit working
The tach on my daughter's 92 Accord LX 5 speed with 176k miles quit working today. I tried the search function on this board, but couldn't come up with anything. Is this a common problem? Is there a usual fix? I appreciate any help you can give me.
Thanks,
Dale
Old Jul 3, 2008 | 07:53 PM
poolman's Avatar
Default RE: Tach quit working
Mine did the same thing 2 weeks ago and I just tapped on the cluster and it came back on. It has been working ever since.
Old Jul 3, 2008 | 08:33 PM
Tach can quit when there's an ignition problem (coil or ignitor). It's not a common problem. If car is running fine, I agree w/ poolman, probably a bad instrument panel circuit or rpm gauge assy. If this is confirmed, then easiest fix is probably a used instrument panel. You'll need to file an mileage adjustment statement w/ your DMV. The 94-97 manual can be downloaded from Onlink Manuals DIY procedure.
Old Jul 3, 2008 | 10:28 PM
The tach signal is generated by the ignition control module. If hitting the gauge cluster doesn't solve the problem, then I would check the ICM connections inside of the distributor (has four wires going to it).
Tony1M
Nov 6, 2023 08:29 PM
BSims66173
Nov 9, 2012 11:52 AM
bglovept
Aug 25, 2010 07:50 PM
zoominhuman
Mar 23, 2007 10:29 PM
fuctcivic
Nov 17, 2006 03:34 AM
