tail brake lights don't work
Old Oct 15, 2016 | 02:51 PM
HACKITOFF's Avatar
Default tail brake lights don't work
2009 honda accord ex-l. tail brake lights don't go on when I step on brake pedal but 3rd light works. have tested the following - cruise control works. horn works. bulbs flash when I press on key fob to lock doors. flasher and back up lights work. no warning lights on control panel. any ideas?
Old Oct 15, 2016 | 03:27 PM
1. Have you checked that the bulbs are actually okay? They are dual filament bulbs. One filament for the taillight and one for the brake light.
2. If you have a voltmeter, you can test if there is power on the Lt Grn wires with the brake pedal depressed.
3. Both brake lights share a common ground. The ground is G602, located on the left side of the trunk area. You'll have to remove the plastic trim panel.
jarronn13
Mar 19, 2016 05:53 PM
BmxJsh6
Sep 18, 2012 09:58 PM
myfirstisanaccord
Apr 24, 2011 08:25 PM
Jodi
Sep 8, 2010 05:54 PM
Ranger
Dec 9, 2009 12:17 PM
