2004 Accord Brake lights don't work
Old Sep 8, 2010 | 01:42 PM
Jodi's Avatar
Default 2004 Accord Brake lights don't work
Both brake lights went out at the same time. (third upper light still works) Fuse is good.
Car as 105,000 mi. on it.
Any suggestions?
Old Sep 8, 2010 | 02:51 PM
Are the brake lights the only bulbs not working in the back?
The brake light switch is working, since the high mount brake light works.
That leaves the wiring, or both bulbs burned out. Unplug a non working bulb. Look at the bulb to see if the filament is broken. If there are more than two wires going to the bulb, then there are multiple filaments in there.
You can also use a volt meter on the brake light bulb socket. With the headlights turned off, and someone pressing on the brake pedal, one of the wires should have 12V to ground. I would find a metal bolt in the trunk area to use as a ground.
Old Sep 8, 2010 | 02:57 PM
deserthonda's Avatar
chk to make sure there is power at the white/black wires and ground at black wires if so, try a new bulb
Old Sep 8, 2010 | 03:02 PM
Jodi's Avatar
Red face
Yes
How likely is it for both bulbs to burn out at the same time?
Filaments look OK but will will check with VOM
I will try that.
One more thing--I had the front brakes replaced a week ago Saturday. I called Honda and they said that couldn't have anything to do with the brake lights not working.
I'm not the most technical person in the world.... (65 year old lady) but I am trying to avoid going back to the dealership unless I HAVE to ;-)
Thanks,
Jodi
Old Sep 8, 2010 | 05:46 PM
The brakes should have nothing to do with your brake light problem.
DesertHonda gave you the wire colors, so check for voltage and ground at the brake light electrical connector.
Old Sep 8, 2010 | 05:54 PM
Jodi's Avatar
Thanks all... it was the bulb afterall.. filaments were OK, but with VOM, bulb was not burned out. I will get new bulbs and hopefully it will be fixed!
Appreciate your help,
Jodi
jmsmiller4
Jan 3, 2014 05:36 PM
BmxJsh6
Sep 18, 2012 09:58 PM
Simmons
Aug 18, 2012 06:04 PM
crimedog76
Jan 4, 2012 06:45 PM
Ranger
Dec 9, 2009 12:17 PM
