Tapping from driver's side dash, '07 2.4l
Old Jul 14, 2016 | 07:16 AM
CHUCKW's Avatar
Default Tapping from driver's side dash, '07 2.4l
Recently I have noticed a tapping noise coming from the driver's side dash area, around the vent. The sound does not seem to be connected to the fan because it doesn't speed up as the fan is turned up. The tapping begins at start up but then goes away after a couple of minutes. It is more of a plastic on plastic sound rather than a metal on metal. Any ideas?
Old Jul 14, 2016 | 08:19 AM
rockhoundrob's Avatar
I have a 1998 Accord, so I don't know if the 07 has the same type of arrangement.
1) open the fusebox cover on the driver side and see if it's louder. It might be a relay.
2) It could be the vent door actuator. They move the doors according to the setup of your climate control (hot-cold, recirculate, etc..). Try turning the climate control off just as you start the car and see if there is a difference.
Old Aug 1, 2016 | 12:06 PM
CHUCKW's Avatar
The sound is not so much a tapping as it is a fluttering. Almost as if there was a leaf stuck in the vent but it does not do this all the time nor does the speed increase with the fan. I tried turning off the climate control but it still happens.
Old Aug 10, 2016 | 08:18 AM
CHUCKW's Avatar
Anybody have any ideas about this "fluttering" noise?
Old Aug 10, 2016 | 07:20 PM
Noises are tough to identify over the web. Can you try to remove the glove box and pin-point the location of the noise?
Old Jul 17, 2017 | 05:46 PM
CHUCKW's Avatar
I think I might have discovered it. After nearly a year I found this video on Youtube.
I ordered the part from HondaPartsNow, and will give it a try this weekend.
Old Jul 24, 2017 | 07:53 AM
CHUCKW's Avatar
That fixed it. It was the motor that controls the a/c and heat mixing door that was making the noise. Pain in the butt to replace. Very difficult getting to the part under the dash. Had to remove a bracket that bolts to firewall and dash.
jza240sx
Apr 30, 2013 04:14 PM
iimzii85
Nov 1, 2010 01:16 PM
ndp
Jun 7, 2009 05:23 PM
19accord92
Apr 10, 2006 03:52 PM
