Tbelt tensioner spring
Old Feb 23, 2012 | 02:08 PM
gasguzzler's Avatar
Default Tbelt tensioner spring
Working on an 87 accord with 118,000 miles and wondering if most people change the spring along with the tensioner when doing a tbelt change or should the original spring be okay?
Thank you
Old Feb 23, 2012 | 03:30 PM
The spring is pretty cheap for peace of mind. If the spring doesn't look stretched or rusted, then you can reuse.
Old Feb 24, 2012 | 02:16 PM
gasguzzler's Avatar
Okay thanks. One other question.. the rubber washer that goes around the tensioner bolt.. does the washer go outside the cover or inside the cover? Is it all that necessary? I assume it just seals out dirt? Mine in torn in two and I don't have a replacement..
Thanks again.
Old Feb 24, 2012 | 02:40 PM
I think it goes inside the cover. I remember someone on here used a rubber washer from a garden hose for that seal. If you have a garden hose, give it a shot and let us know if it works.
Old Feb 24, 2012 | 03:04 PM
Talking Hi Gas Guzzler**
Is this what your part looks like.?
Old Feb 24, 2012 | 03:24 PM
gasguzzler's Avatar
Yep, that looks like the one.
Old Feb 24, 2012 | 05:33 PM
hwr98013's Avatar
Just be sure the hose does not fall inside the cover, that could be bad. I'd find an e-clip of the right size, from the outside of the cover slide it onto the bolt that sticks through-where the "indent" on the bolt is. Then if you are worried about dirt getting in, add a dab of silcone around it.
Old Feb 25, 2012 | 05:50 PM
kyle102565's Avatar
the spring is redundant, a Honda staple and why they are so damn good.
like already stated, for piece of mind change it, though i never do.
Old Mar 4, 2012 | 12:59 AM
gasguzzler's Avatar
Thanks
Stonent
Aug 2, 2012 07:18 PM
jarede7
Dec 5, 2008 11:37 AM
el toro
Nov 1, 2006 09:20 PM
DrakeRake
Jul 15, 2006 08:50 PM
vdabis
May 2, 2006 02:42 AM
