TCM Removal
Old Nov 3, 2011 | 06:42 PM
KelvinR's Avatar
Default TCM Removal
Can anyone link me to a picture on how to remove the transmission control module of a 1996 honda accord coupe? Thanks in advance!
Old Nov 3, 2011 | 07:03 PM
Looks like in 1996 the ECM and TCM are in a combined module. Same location under the passenger foot well carpet. Pull back carpet, remove 4 bolts, remove electrical connections and remove module and cover. Separate ECM from cover.
Old Nov 3, 2011 | 07:16 PM
KelvinR's Avatar
4 bolts is all? hmm ok thanks a lot. but hey let me ask you a quick question. My combination fuse/back up light keeps blowing every time I shift the car to reverse. I checked all the cables in the back and all seem ok. every thing else works. So can it be a a bad cable going to the tcm which ive read is what turns on the lights.
Old Nov 3, 2011 | 09:54 PM
ECM is not the problem. This circuit has no connection to the ECM.
Things to check:
1) AT Gear Position Switch (in the console). It may be shorted to ground, or someone pinched the wiring during console removal/installation.
2) Trailer Light Connection in trunk. Even if no trailer, it might be shorted to ground
3) Backup Light receptacle (short to ground in wiring or receptacle).
Somewhere there is a short to ground. You can pull the No 1 fuse in under dash fuse box and check circuit. It should be open. If it shows a short to ground (almost certain), you must find the short as suggested above.
Old Nov 3, 2011 | 11:21 PM
KelvinR's Avatar
I pretty much checked all of those except the gear position switch which i will check tomorrow. but for some reason when the fuse blows I cant get out of park... so most likely some thing is messed up inside there.
Thanks!
shutupbiyaatch
Feb 16, 2016 08:08 PM
wish234
Feb 23, 2009 04:29 PM
stauff99
Sep 5, 2008 11:17 PM
FELON
May 31, 2008 07:35 PM
appleman
Sep 27, 2007 11:44 AM
