TCS light and brake light staying on
Old Jan 31, 2008 | 11:14 PM
drtysohc
Default TCS light and brake light staying on
So, the other day my TCS light came on, and TCS is no longer working. It resets every time I restart the car. I noticed that the brake light on the gauge cluster is staying on. I read that the brake light switch down by the pedal could be the culprit. Is that the case? Does anyone have the part number for it? I did some searching, but I couldn't find how to test the switch(es), or which one it usually is.
Thank you in advance for any help.
-Steve
Old Feb 1, 2008 | 12:04 PM
HondatechAV6's Avatar
Default RE: TCS light and brake light staying on
the red brake warning light can cause tcs deactivation, as well as check engine lights. what year and trim level?
a bad brake light switch will not cause the red brake warning light to illuminate.
Old Feb 1, 2008 | 08:52 PM
drtysohc
It is an 03 EX v6. I'm sorry, I thought that I already said that
Do you think it could be the e-brake switch, or something more serious?
Old Feb 2, 2008 | 12:21 PM
yes, it could be. if the handbrake was left on it could set a tcs code.
is the red brake light on upon startup?
have you checked the brake fluid level yet?
Old Feb 2, 2008 | 04:09 PM
drtysohc
The brake fluid is way above the min. line...
And yes, there is a brake light upon startup, and it doesn't go off. About 15-20 seconds later the tcs symbol and "TCS" light come on together.
Old Feb 2, 2008 | 05:03 PM
sir_nasty's Avatar
Is your ebrake functioning normally? Is the weather in your area in the freezing temps? Do you leave your e-brake on overnight.
Old Feb 2, 2008 | 08:50 PM
hmm..try disconnecting the connector plugged into the brake master cylinder while the car is off.
then start it up. is the brake warning light off? if so, and the car has never been in an accident,you have to replace the BRAKE MASTER CYLINDER!! isn't that dumb??!
the reason the tcs light is coming on is because of the brake warning light.
have fun!
Old Feb 3, 2008 | 12:21 PM
drtysohc
ORIGINAL: sir_nasty
Yes, the weather has been really cold, but I don't always leave the e-brake on.
ORIGINAL: HondatechAV6
have fun!
Interesting. I'll check it out, hopefully that isn't it....Why the heck can't you replace the sensor? That is retarded.
Just out of curiousity what does it have to do with being in an accident? I don't think it has been in one, but then again I didn't do a carfax on it. If it has been in an accident, what would change?
Thanks for your help
-Steve
Old Feb 3, 2008 | 03:23 PM
drtysohc
I unplugged the low brake fluid sensor on the resevoir and the brake light went off, so I guess that is what it is.[&o]
dav8948
Dec 3, 2013 08:41 PM
ramman949
Aug 14, 2012 06:05 PM
Akkord2k1
Oct 24, 2010 04:19 PM
OhThreeVeeSix
Sep 25, 2009 02:12 PM
mxxmikexx
Aug 11, 2006 02:18 PM
